Asus Strix MB: Hail Mary on USB Port Power Issue
Mr_Savy
I need the expertise of this community. I'm at the end of my troubleshooting skills. I am trying to avoid the potential ultimate solution which is to reset the PC on my Windows 10 machine.
Problem: After the computer sleeps for awhile AND then rebooted sometime later, the computer will go through the boot sequence but when it gets to the logon screen there are no powered USB ports. This makes it difficult to log in, like can't. Nothing I do in the bios will fix the issue.
Work Around: I boot to a USB drive with Windows Repair, restore from a fairly recent Restore Point (note: repairing Windows does ever find any issues). Reboot and everything works. However not every RP works, only some. Some RP's where I was careful to update virus, windows, drivers (where needed), etc after no USB but b4 creating a RP, won't work. Seems like they should. The no USB port after boot sequence will still occur the next time I boot.
What I know: If after I restore, do a short sleep then reboot, no issues. So it seems to occur after longer sleeps. For sure overnight. Why a restore works and some don't, can't figure that one out.
MY SYSTEM:
Asus Strix MB, latest bios, UEFI
Intel 6800K
EVGA GTX 970
Corsair Dominator Platinum DDR4 3200 16G
Boot Drive: Samsung 960 Pro m.2
Windows 10 Installed from scratch early 2017
Running latest W10 version
Corsair M800 Game Pad
Corsair Platinum K95
Things I've tried (seems like everything):
Tons of internet searches. Others have had this issue. When they have found solutions, they don't work on my system. Tried what I think are most of the other suggestions out there. Hopefully I just missed one.
Disconnect all USB devices except keyboard and mouse + all drives except boot drive
In bios setting various of:
C-States
Fast Boot
USB xHCI
Default bios settings
CSM Launch
I'm sure I missed sharing other settings I've tried
In W10
USB Power Mgmt (unchecked all allow computer to turn off)
Updated ASMedia USB3.1 eXtensible to v1.16.49.1 (tried other lower version drivers)
Bluetooth Qualcomm & Microsoft drivers
Adv Power Options (Drive sleep never, no hybrid)
Ran chkdsk, no issues
Ran sfc /scannow, no issues
Event Views shows a reasonable number of DistributedCOM errors (I know how to fix them, fixed some b4, but don't think that's the issue)
Since I've owned the Strix, I always get Event 137, "system firmware has changed the processor's memory type range registers (MTRRs) across a sleep state transition (S4). This can result in reduced resume performance. However this USB issue is something I encountered around the November time frame
Always keep W10 update when updates are available
Always keep virus & malware up-to-date (NIS, Malwarebytes)
Always keep software Up-to-date
For awhile I though the issue maybe either Logitech Gaming Software or Macrium Reflect (maybe an update). Uninstalled but same issue occurs. Some people have thought issues were generated due to the Fall Creators update of W10. So maybe that's the issue.
System works pretty well if the computer is never rebooted.
So this is my hail mary to you experts. I'm trying hard to avoid a PC Reset because it is super painful. Lots of applications and take15-20 hours to get back up and running. Want to avoid at all costs but I may be destined to do that. I'm hoping there might be a registry change that can be an easy work around.
Thanks in advance for any ideas!!!
0 REPLIES 0
