02-15-201502:15 AM - last edited on 03-06-202403:29 AM by ROGBot
Hello can anybody tell what can I do to get the fans working ? My laptop is overheating even when I'm just navigating on internet. I can't play games because it gets over 65 degrees celsius.
Are both of your fans working properly? Your pc is overheating due to lack of airflow inside. Thats really bad. You either need to get your fans cleaned or if your fans are broken then youll have to replace them. If anything is blocking the vents that will also cause your Asus to overheat. One of my fans seems to be disabled. I havent even had this laptop for a year.
