Asus Rampage Extreme V CPU Power connector, 8pin/4pin to 8pin. Cant find Replacement.
Terriblecookies
Anyone know where I can pick this MB cpu power connecter up I have been looking everywhere with no luck.
Praz
Hello
Using an adapter that would allow an 8 pin cable to populate both the 8 and 4 pin +12V EPS headers would accomplish nothing. The end result would be the same as using only an 8 pin cable. Perhaps this is why you have not located such an adapter.
