Asus Crosshair x670 Extreme Water Leak Detected Error Message
GhostGamingPR
Hi im having troubles with my Asus Crosshair x670 Extreme After Few Minutes Of Using The PC This Message Appears And Shut Down Alone The Motherboard Dont Have Nothing No Leaks Dont Have Nothing How Can I Fix This Expensive Monitor Please Anyone Can Help Me Thanks in Advance
Silent_Scone
Super Moderator
Hi @GhostGamingPR
Has this a new build or has this suddenly started happening after a change or out of the blue?
Are you using an AIO or custom water cooling?
It could also be moisture on a sensor. Is it humid where you are?
Ensure you're on the latest BIOS
Im using a custom water cooling loop but dont have a single leak or nothing thats why i dont know whats happends i live in a warm area no humid here
