07-01-2017 10:15 AM - last edited on 03-05-2024 10:15 PM by ROGBot
07-01-2017 04:20 PM
07-05-2017 08:39 PM
07-05-2017 08:51 PM
ASUS-OP wrote:
Hi ItsImportant,
1. Yes, 1.04.43 has already fixed the SPD corruption issue.
2. Yes, Corsair Vengeance RGB DDR4 modules are now supported with the new version.
3. They may or may not work. The QVL list is a list of kits previously tested in house to ensure reliability with such configuration. We will suggest to check on QVL list from both motherboard or device vendors. If either one listed them as working, you should be pretty much safe from trouble with such combination.
4. Please provide the exact PN and revision of the kit you are referring to. This will enable us to find out the exact info you need.
regards,
