03-07-2017 02:41 PM - last edited on 03-05-2024 10:44 PM by ROGBot
03-07-2017 02:48 PM
03-07-2017 02:55 PM
xeromist wrote:
It looks like the insulation may not actually be broken. You don't want the wires to be repeatedly crushed as they could get damaged but as long as the copper wire inside isn't broken or exposed everything will still work. Did it stop working?
03-07-2017 03:09 PM
03-07-2017 03:14 PM
xeromist wrote:
The only way to get an official replacement cable installed would be RMA. ASUS doesn't sell those separately.
If RMA doesn't work for you then those leads could be repaired by someone with basic electronics skills. Any shop that does electronics repair could fix that wire. However, if the insulation did get broken then there could have been a short which would damage the electronics. Repairing the wire wouldn't be enough if something else has been damaged. I would inspect the area for melted wire or scorching.
03-07-2017 03:17 PM
