02-28-2022 07:05 PM
04-18-2022 02:34 AM
04-18-2022 02:55 AM
04-18-2022 04:27 AM
STARRAIN@ROG wrote:
Hi axiumone and Unstable_overclock,
Thank you for your reply.
Do you install rog gamfirst VI?
Do you have the issue when use Windows Explorer to transfer files through internet? or only have the issue when use steam downloading games or discord call?
If there is no issue when only use Windows Explorer to transfer files through internet, could you please also play a youtube video meanwhile to see if the issue occurs?
Thank you so much.
04-18-2022 08:09 PM
04-18-2022 08:10 PM
04-20-2022 04:29 AM
04-20-2022 03:51 PM
STARRAIN@ROG wrote:
Hi all,
When the ethernet shows 0, is the connection back to normal after few seconds or it will show 0 constantly?
When the issue occurs, if you open the browser, does it show internet access or no internet connection?
When the issue occurs, if you pin google in cmd, does it show internet connection or lost?
If you replug the ethernet cable in, is the connection back to normal?
04-20-2022 08:22 PM
04-25-2022 11:17 PM
