04-24-2022 12:52 PM
11-11-2022 04:15 AM
STARRAIN@ROG wrote:
Hi nordx,
Do you mean USB devices will disconnect? Does it occur when transferring files?
Which devices and US ports did you use and have disconnecting issue?
Does it also occur on bios 2103 with bios all default settings(no OC)?
Have you tried updating PD FW Version 008 and Intel ME Version 16.1.25.1885 from our support site?
01-07-2023 02:36 AM
nordx wrote:
also update from PD FW 0006 to 0008 (i saw that there is a Version checker at the asus download page and found out its not the newest).
01-25-2023 05:57 PM
Aurosonic wrote:
Where did you find PD FW 0008 ? I can't find it anywhere. Only 0004. I've a problem with USB C and connected Apple Magsafe charger to it. It makes bios init and all bios keyboard and mouse movements sluggish. Like bios init take about minute and then post menu minute. All the movements in bios by keyboard take like 10-15 seconds after pressing any keyboard key. Problem away whenever i unplug MagSafe from USB C port from backpanel of my Apex Z690. I've update Intel ME to latest. My bios version is 1403. Now all is left to try is to update USB PD FW to 0008. Mine is 0004 right now.
02-07-2023 10:09 AM
nordx wrote:
i also needed a second look cause i couldnt find it right away now...
https://rog.asus.com/motherboards/rog-strix/rog-strix-z690-a-gaming-wifi-d4-model/helpdesk_bios/
11-11-2022 09:42 AM
11-13-2022 07:32 PM
04-10-2023 01:13 PM - edited 04-10-2023 01:15 PM
I too have an issue with USB devices malfunctioning. I don't remember having this issue from the beginning so I thought it might be related to Windows 11. It started with random static in my headphones which still happens occasionally but the weird part is my Oculus being unable to connect sometimes and my keyboard or mouse simply stop working. I found out that the sleep function is Windows is partly to blame. If the computer wakes up from sleep I loose one or more devices after a little while so I stopped doing that. I still hear the static noise in my headset now and then though.
One thing though. Someone wrote here that the problems went away with an update to PD FW version 008 and my motherboard is the ASUS Prime Z690-A and on the official website there is only a version 007. The motherboards seem closely related so I thought it might work but I haven't had the guts to try it out.
Here's the site for my board:
https://www.asus.com/motherboards-components/motherboards/prime/prime-z690-a/helpdesk_bios/?model2Na...
Newer version available here for a different but very similar board is here:
Release notes don't say anything about USB stability or power issues being fixed though.
Have anyone any experience or info about this?
