STARRAIN@ROG wrote:
Hi X-Men,
I'm sorry I didn't notice you have mentioned the cpu model name.
Could you please install the ssd in m.2_3 slot and see if is it the same?
Thank you for your reply!
That stroke my mind too, see if it will work in m.2_3 slot.
But I did not do that!
Â*My mind said that I should replace the PSU. The PSU works fine, no problems what so ever. It has been tested on two other PCs without any problems.
Â*Despite that I got myself a new PSU today. I replaced the present PSU and then, like magic, the PC works!
I have only motherboard, NVMe SSD, RAM, CPU and CPU cooler connected to the motherboard. No external graphics, no internal disks, no extra USBs connected or anything else. Just motherboard, SSD, CPU, RAM and CPU cooler.
With a new PSU it seems to work. i have cold started the PC several times, first with one USB drive connected, then two USB drives conneted and finally I ended up with three USB drives connected. PC boots up just fine!
Even restart works fine so far.
I estimates that I have powered up the PC (cold start) 10 times and no fault. Restarted 2-3 times and no fault!
Solution on my problem is (was) replacin the PSU.
The prevoius PSU is not running fine in another PC.
Thank you for your kind support!Â*
