X570-f | STRIX HELIOS | Front Panel Wont Light Up
itsyaboirich
Is the front panel won't lights up if there's no gpu installed yet on my pc? I haven't got the gpu because im still waiting for the stocks. All the front panel cables are plugged in except for the one usb 3.0 because there is no more slot. I also tried holding down the led button for 6 seconds but still no lights. Please help 
Blake1
Hello itsyaboirich,
May you double check if your RGB headers are connected and you didn't turn of the lighting setting in BIOS?
Hi Blake@ROG,
Thank you for your reply. Yes, the rgb headers are connected. I don't have gpu yet i just checked if it boots and i noticed that the front panel rgb has no lights. Can i access bios without gpu? Im still waiting for the stocks of gpu 😞
Blake1
Hello itsyaboirich,
Does your CPU have a integrated display card? then you are able to access BIOS.
