Wake on LAN not working on driver higher than 1.0.1.4 on l255-V
kormyr
Basically what the title mentions. On a B550-F doesn't work and neither on a Z590 board. Installing driver 1.0.2.8 offered by armory crate breaks the WOL functionality. Reverting to 1.0.1.4 makes it work back inmmediately. This is on a onboard lan intel l225-V.
14 REPLIES 14
Thunderspell wrote:
Am Facing the same Problem here:
1. ROG STRIX Z590-E GAMING WIFI, BIOS 1007.
2. ethernet controller driver - 1.0.2.8.
3. i7-11700k, Windows 10 Pro 21H1 (Build 19043.1288), all updates installed.
Tried with Fast Startup Enabled and Disabled didn't work, till i found that Post.
guys if you found a solution can you please post it here it may help me and other
Thank you in Advance
Hello Thunderspell,
Would you mind to record a video of how you set up WOL
and how it does not work?
Blake1
Hello Alex,
Thank you for the information.
I have passed them to related department for further investigation.
Blake1
Hello Alex,
Can you help to record a video of the whole process and issue?
We have tried driver 1.0.2.8 and the PC can WOL from S5.
farrsight
Anyone resolve this issue? I have a problem with this controller except that WOL works, but only if it's connected to a 1gbe port. When I connect to a 2.5gbe port WOL stops working.
TUF Z390M-PRO GAMING, i5-9600, 2x8GB 3200Mhz G.Skill Trident RAM, Corsair H100vi2 AIO Cooler, Win10x64
STARRAIN_ROG
Customer Service Agent
Hi farrsight,
Do you mean WOL is working with Intel I219V LAN controller 1gbe port but not working with 2.5gbe port?
May I know how you try 2.5gbe port on TUF Z390M-PRO GAMING (WI-FI) motherboard?
May I have the bios version, OS version and LAN driver version?
