Wake on LAN not working on driver higher than 1.0.1.4 on l255-V
kormyr
Basically what the title mentions. On a B550-F doesn't work and neither on a Z590 board. Installing driver 1.0.2.8 offered by armory crate breaks the WOL functionality. Reverting to 1.0.1.4 makes it work back inmmediately. This is on a onboard lan intel l225-V.
14 REPLIES 14
kormyr
Bumping thread. Any moderator could take a look? I reported this to support but not too much luck.
I have the same issue on the Z590-F
Alexx69rus
Same on Z590-E
Found driver 1.0.2.13 https://www.driveridentifier.com/scan/intelr-ethernet-controller-3-i225-v-driver/driver-detail/A1093.... Looks like it solved problem for me. Successfully woke up the system five times in a row at the moment.
Alexx69rus
Unfortunately, this did not help. With 1.0.2.13 or 1.0.2.14 WHQL the system wakes up several times, and then stops until you turn off the power.
1.0.2.14 solves it IF you disable fast startup in windows. Not ideal, because 1.0.1.4 works with fast startup but this is as far as I got.
Blake1
Dear all,
Please refer to below link
https://rog.asus.com/support/FAQ/1045950
May you help to provide below information so I can consult more about it?
1. complete model name of the motherboard and current BIOS version
2.current ethernet controller driver version
3. CPU spec and Windows version
Thank you very much.
Blake@ROG wrote:
Dear all,
1. ROG STRIX Z590-E GAMING WIFI, BIOS 1007
2. ethernet controller driver - 1.0.2.8 (I tried all versions, including 1.0.1.5 from FAQ)
3. i9-11900k, Windows 10 Enterprise 21H1 (10.0.19043.1165), all updates installed
I installed TP-link TG-3468 network card, WOL works stably with it in 100% of cases.
Created ticket in support:
ASUS Service No=E21070059795-0011
Am Facing the same Problem here:
1. ROG STRIX Z590-E GAMING WIFI, BIOS 1007.
2. ethernet controller driver - 1.0.2.8.
3. i7-11700k, Windows 10 Pro 21H1 (Build 19043.1288), all updates installed.
Tried with Fast Startup Enabled and Disabled didn't work, till i found that Post.
guys if you found a solution can you please post it here it may help me and other
Thank you in Advance
