USB Microphone (w/ USB Audio Interface) problem on ROG Zephyrus M16
mhatta
I recently bought ROG Zephyrus M16 (GU603HE-I7G3050TEC) and am trying to use AKG Lyra, a USB Microphone. The OS has been upgraded to the latest Windows 11 Home and I believe I have all ASUS utilities, BIOS, drivers, etc., up-to-date.
For some reason, the audio quality is terrible -- very condensed, noisy, and too fast. The AKG mic (which has its own USB Audio Interface) is perfectly fine with other Win11 laptops, so it seems it is not a hardware failure of the mic.
Also, other USB mics without USB Audio (I tested with Maranz MPM2000U and Razer Seiren Mini) are fine with this ROG laoptop. So I guess some ASUS-specific driver or such are messing with AKG Lyra's USB Audio, but I couldn't figure out the culprit. Any advice?
Thanks in advance!
14 REPLIES 14
Blake1
Hi there,
Can I have a video or audio record to compare the difference or understand the issue more?
Blake@ROG wrote:
Hi there,
Sorry for late reply.
https://1drv.ms/u/s!AsP-eizg139wiJoNWiRK-FhGdh71XA?e=h3fIRQ : This is a "bad" example, recorded on ASUS ROG Zephyrus M16 with Win11's Voice Recorder app with AKG Lyra USB microphone
https://1drv.ms/u/s!AsP-eizg139wh_l2noJH5RQwlrCz5Q?e=GMLf6f : This is a "good" example, recorded on a non-ASUS laptop with Win11's Voice Recorder app with AKG Lyra USB microphone
Hope it helps.
Blake1
Hi there,
Thank you so much for the audio record.
May I know if you have tried all the USB ports on M16?
And please kindly contact the Mic Supplier to see if there is new firmware to update.
I will consult more about it.
Blake@ROG wrote:
Hi there,
Yes, I tried both USB-A and USB-C ports of M16. AKG Lyra comes with a USB-C <-> USB-A cable, but i have Anker's USB-C <-> USB-C cable, so I tried with it, too.
Also, AKG looks like it doesn't provide any firmware updates for Lyra (yet). https://www.akg.com/Microphones/Condenser%20Microphones/C44-USB.html
Any updates?
Blake1
Hi mhatta,
It is very likely a compatibility issue.
I will consult more if there is anything we can do about this.
Please kindly keep feedbacking to the Mic supplier as well.
Thank you very much.
Seems It is a common issue, It seems it is Isst driver, I've tried to solve the problem like here https://proforums.harman.com/akg/discussion/138052/akg-lyra-not-working-on-windows-10#latest , but it seems Intel ISST catches the output.
Astromancer
I had the exact same issue - atr2100x microphone - works fine on old machine. Compresses, accelerates, and distorts incoming sound. Eventually I stumbled over the intel smart sound driver as the problem. Then went to device manager, scrolled down to sound devices, disable smart sound, and poof - Microphone now works. There is some sort of mismatch between the intel smart sound driver and windows or asus bios.
Update - a few days later I installed a docking station and windows update found about 6 or 7 drivers that hadn't been identified before - including one for the microphone I 'm using - that solved the problem. I can't say if I missed the link before or if windows update didn't display it regarding the assorted drivers. In any case intel smart sound now is working properly with my usb microphone.
mhatta wrote:
Thanks in advance!
Hi!
I have the same issue.
The problem is in the Intel ISST driver.
I also noticed when the audio is muted - a strange noise appears whenever any sound is played - here is an example https://disk.yandex.ru/d/GjNTt5Mutf4VJQ .
Best,
Evgeny
