10-28-2020 09:01 PM
"When play the game , fan start to spin with high RPM. The noise sounds like coil whine , so I thought it was coil whine and ignore the sounds. Last night the noise got worse so check the card , and the sounds came from the LED cover. When I press the LED cover noise disappear. So it seems the fan may contact the LED cover on high RPM. For me it happen when card is under load so fan start spin. Around 70% of fan speed is makes the noise. I found the left fan makes the sound for me(to find out I have stop the fan with my finger)."
"I noticed the same issue on my 3090 Strix OC last night too.
I can replicate it 100% of the time by just turning up the fan speed with the card at idle. It seems loudest for me at about 65% and the middle fan seems to cause it more.
Pushing on the lightbar doesn't make it go away completely but does decrease the sound significantly. Unlike in your video it decreases the vibration sound when I push on the lightbar on the right hand side (power plug end) of the lightbar about a third of the way along. Pushing where you did does nothing for me.
In all other respects the card works fine it's just a ****ty design/QC."
11-16-2020 11:46 PM
11-18-2020 07:21 AM
Blake@ROG wrote:
Dear all Strix RTX 3090 users,
If you have encountered the fan vibration issue.
Please kindly PM me below information. (All are required)
1.Full name
2.Current Location( country/region)
3.email or phone number
4. product serial number
We are trying to provide solution on this but need to prepare them first then we will reach out to you.
Thank you so much.
11-18-2020 10:26 AM
11-17-2020 06:50 AM
11-18-2020 02:59 AM
11-18-2020 11:33 AM
12-12-2020 12:58 PM
12-12-2020 04:56 PM
XskullbangerX wrote:
**UPDATE**
I'm not sure what finally did it, but on November 24th I was contacted by asus over the phone and they gave me the option to use their Advance Replacement Program. I didn't even know that such a program existed. I allowed them to put a hold on a credit card and they sent me a new card, allowing me 14 days to send mine back. Once I got the card it wasn't in a retail box, but was packaged nicely and had the protective film on the light bar that was missing from my retail card. Card ran a tad cooler and clocks were just as good. I sent mine back the same day. They've since recieved it and dropped the hold on my card. New card has no fan issues so I'm happy now. I'm not sure what qualified me for the advance replacement. Maybe I complained enough.
We should make a list of all the people who's retail card didn't have film on the light bar, and then what retailers we got these from. Good luck to all and I hope your situations are resolved as well!
12-12-2020 05:38 PM
funk3r wrote:
What was the phone number that asus contacted you with it atleast, or the area code if you do not want to share it? When did you contact Blake? I still have not received a call or email yet, just a reply from Blake stating that they'll be in contact with me.
12-12-2020 06:10 PM
Megascrypt wrote:
There is quite a few of us that still didn't receive any further info from either Blake or Asus itself, so let's hope that this is a good sign and things are moving in the right direction:)
