04-17-2022 07:42 AM
05-26-2022 06:20 PM
05-29-2022 08:54 AM
06-20-2022 08:17 AM
05-29-2022 08:10 PM
06-14-2022 07:17 PM
06-20-2022 02:44 AM
06-21-2022 12:31 AM
06-21-2022 01:12 AM
STARRAIN@ROG wrote:
Hi sblantipodi,
Please refer to the following link to see if there is any dirt on the CPU, CPU pin, memory pin or memory slot of motherboard. If so, please clean them and try again.
https://www.asus.com/support/FAQ/1042678
06-21-2022 08:29 PM
06-22-2022 12:53 AM
STARRAIN@ROG wrote:
Hi sblantipodi,
This suggestion is from our tech team, because they test the motherboard and device at hand, found qcode 01 twice(the rgb light is normal) after weeks testing. But after clean CPU and memory pin, they don't see qcode 01 so far.
Also, they found iCue rgb stopping issue few times, and will do more experiment.
