02-24-2023 10:23 AM
02-24-2023 12:32 PM
02-24-2023 08:29 PM
02-25-2023 04:51 AM
Mevil43 wrote:
1) Are there any important differences between installing my audio drivers using AsusSetup.exe vs. Setup.exe? If there are differences, what are they? Should I be using one over another?
Mevil43 wrote:
2) What is the Sonic Studio Virtual Mixer and how is it different from my Realtek(R) Audio?
]"Sonic Studio Virtual Mixer : Mix your voice and video game audio together using this software specifically designed for streaming applications. A variety of settings and monitoring."
Mevil43 wrote:
Where exactly does this app come from? Is it installed because of the AsusSetup.exe?
Mevil43 wrote:
Does it come from Windows Updates?
Mevil43 wrote:
If it comes from Windows Updates, why is it not installed when I install using the setup.exe?
03-06-2023 11:33 PM
03-01-2023 10:41 PM
3 weeks ago
Hey,
I think you should have to update your realtek audio driver directly from realtek website and then your driver will be updated. Asussteup.exe is not for realtek audio. To Update it in the easy and quick way you can go through the helpful guide i.e - Update Realtek Audio Driver
I Hope it will help you.
I also have a question regarding my Cousin's Asus Laptop
As we have Recently purchased the ASUS TUF Gaming A15 Ryzen 5 for my Cousin. We are facing the stuttering issue on GTA 5 Game. Is there any solution realted to the same
