realtek audio driver installation question
Shocker
I installed audio driver from viii hero site, i opened asusetup.exe instead original setup.exe, it first installed vc_redist because it is freshly installed windows, and after that nothing happened, no confirmation or anything that audio driver is installed, but i checked device manager and it says it is installed, along with control manager. Is it normal behavior?
Nate152
Hi Shocker,
You can use either Asus setup or original setup.
Open Asus setup the first time to extract the files, click Asus setup again to install.
