06-14-2022 12:32 AM
06-14-2022 06:14 AM
DragDay7 wrote:
Unless QFAN doesn't detect lowest fan speed like in my case. I have 4 DC fans with lowest speed at 28%. QFAN detects it at 28-33%, I've never been able to get 28% in all of them. Thus I just use Fan Control and call it a day xD
Maybe you have another app that controls CPU fan speed? But since you don't like additional software I highly doubt it.
The same cooler works fine when connected to SYS FAN header?
06-14-2022 06:29 AM
plee5509 wrote:
No other apps prior to me installing one to troubleshoot, and it is Fan Control I'm using to take over the CPU Fan and that all works as expected. The same fan on the cooler works fine on another header, as do all the other fan headers, just the CPU one goes in reverse. I've tried all the stock profiles in the BIOS of Turbo, Silent etc as well as manual and the result is the same, the CPU fan is slowing down for a rise in temperature, and speeding up for a reduction in temperature.
06-15-2022 12:13 AM
ahfoo wrote:
Did you try the beta bios on my previous page. It take time and all effort to determine what exactly the problems came from. Having said that, all trouble shooting method worth a try to finalize and reflect the main reason if the bios or hardware causing you the issue. It part to be an PC enthusiastic.
06-16-2022 10:51 AM
06-14-2022 05:27 AM
06-14-2022 05:34 AM
ahfoo wrote:
Hi mate, maybe you want to try the new beta bios to see if it solved your problems.
https://dlcdnets.asus.com/pub/ASUS/mb/BIOS/PRIME-Z690-P-ASUS-1601.zip
Please return to BIOS default if you want to upgrade to this version. If I were you, I will reset the original bios setting before updating to this version. After updating the bios. Reset to default again. I am not sure others, but that my habit for years. Most of them will think I over zealous but that what I do and never go wrong for the past years.
06-16-2022 07:29 PM
06-17-2022 01:49 AM
STARRAIN@ROG wrote:
Hi plee5509,
May I have the following information?
- the serial number of the motherboard via PM
- the brand and the model name of your CPU, RAM, graphics card, OS drive, PSU and pc case
(Please check the specific model name of RAM such as G.SKILL F5-6800U4040G16GX2-TZ5S.)
- OS version and OS build
- pictures of your q-fan settings
Thank you so much.
06-19-2022 08:21 PM
06-24-2022 08:00 AM
