Prime Z490-A: System management bus controller and PCI device not recognized
Freccia2021
Hi, I have the motherboard specified in the title and although I have updated all drivers from the Asus website, when I open Device management I see this:
88563
In the event cards I read this:
The device PCI\VEN_8086&DEV_06A3&SUBSYS_86941043&REV_00\3&11583659&0&FC requires further installation
The device PCI\VEN_8086&DEV_06A4&SUBSYS_86941043&REV_00\3&11583659&0&FD requires further installation.
Can you help me please?
My Computer
MB Asus PRIME Z490-A
CPU i9-10900K
GPU ASUS GeForce RTX 3080 ROG STRIX OC
RAM 32GB DDR4 3600 HyperX Predator
O.S. Windows 10 64bit
4 REPLIES 4
thomas_yiu
thomas_yiu
Did the driver work? Just followup
Sincerely,
TY
Hemimax
I have same issue except after installing drivers the status is "No drivers are installed for this device".
STARRAIN_ROG
Customer Service Agent
Hi Hemimax,
Do you also use PRIME Z490-A?
Which drivers did you install from our support site and saw the "No drivers are installed for this device".?
May I have the bios version?
Did it occur with bios all default settings?
