06-02-2021 11:33 PM
05-24-2022 07:28 AM
STARRAIN@ROG wrote:
Hi IvayloStrix and Serj Ajeossi,
Is the cold boot you mentioned boot after switching the PSU off and on? or does it also occur after restart in windows setting?
Does it occur when connecting ROG Delta to other pc?
How do you check the mic volume?
05-25-2022 05:51 AM
Serj Ajeossi wrote:
No problems after restart in windows settings, only happens when switching the PSU.
Didn't connect to other pc.
I check mic volume in armory crate, click listen from this device, and voice sound is very low, after unplugging and plugging back - voice sound volume 3-4 times higher. Same in discord and other voice related programms.
05-25-2022 05:40 AM
05-24-2022 07:09 PM
05-25-2022 07:23 PM
05-26-2022 09:03 AM
STARRAIN@ROG wrote:
Hi IvayloStrix,
May I have a video while you shutdown the system completely, switching off the psu or unpluging the power wait a bit and when you connect and start to use "listen to device" in Armoury Crate to check the mic volume before and after replug ROG Delta?
Please also share me the OS version & OS build of you pc and rog strix laptop.
Could you please help to check the specific model name such as G513RC and the bios version of your rog strix laptop?
05-26-2022 07:14 PM
05-27-2022 09:36 AM
STARRAIN@ROG wrote:
Hi IvayloStrix,
I'll consult our tech team more about this.
05-30-2022 02:49 AM
06-05-2022 01:09 PM
STARRAIN@ROG wrote:
Hi IvayloStrix,
Our tech team have tested the ROG delta at hand, but cannot reproduce the mic issue you mentioned.
Please follow the steps below to check the mic volume again.
1. remove the ROG delta in device manager when plugged the ROG delta into the pc
2. restart the pc to check the mic volume with "listen to device" in Armoury Crate
3. shutdown the pc and then switch off the psu for 2-3 minutes
4. switch on the psu and then turn on the pc to check the mic volume with "listen to device" in Armoury Crate
If the mic volume still low, may I have a video about the procedure above and the OS version & OS build?
