New RMA Motherboard will not power on randomly.
OgerGe
My old motherboard did exactly the same thing as this replacement board Asus sent me but with 99% rate that it would not power on unless I flicked the power switch on the PSU off for about 5 seconds.
This new board that I received has done the same thing 7 times now since I got it. The Hero leds stay lit as well as the start button on the board but it will not turn on at all. I tried both the start button and the power button on the PC case.
With my original board I experienced so many critical hard crashes. This new board has been stable for the most part, though I have experienced a couple freezes while playing games that it has recovered from. Below is a list of critical power shell error's I experienced with the old board as well as errors with the new board are showing up. From 2/13/2023 is when I installed the new board. As you can see I there are 8 listed and and I have had this problem 7 times with this new board so far.
I would also like to note that the old board would make slight ticking/clicking sound whenever powering on and this new board also does the exact same thing.
My PC components are: AMD Ryzen 5950x, ROG Crosshair VIII Hero Wifi, G Skill F4-3600C17-16GTZR 4 sticks, Gigabyte RX 6700XT GPU, Samsung 980 Pro 1TB
I would also like to note that with the old board the crashes would be more frequent if I had multiple video or game windows opens.
Things I have tried on original board: New power supply Corsair RM 850x, Memtest pass 3 hours 35 minute test with no errors. 2 video cards 5700XT and a RX 590 Fatboy. Fresh windows install. All drives disconnected minus the boot drive. Even used the board with no front panel connection and the used start button to rule that out.
I am honestly so fed up with this Hero Wifi. Never in my life have I experience so many headaches.
My old system works and powers on perfectly fine Crosshair V Formula Z. Girlfriends old system does as well 2 lazy to get the specs. Also girlfriends new system powers on and off normally since day 1. And I built all the PC's listed above. Although both of her boards are Gigabyte.
I would also like to note that I had to pay return shipping for the RMA which is ridiculous considering the price tag on this mobo. Also Asus quoted me a 70 dollar return label they would provide which they stated would be cheaper. Not true.
This is what I get for procastrinating the problem. I should have just returned every single item and said you deal with it.
Critical 3/7/2023 12:48:24 AM Kernel-Power 41 (63)
Critical 3/6/2023 9:41:19 AM Kernel-Power 41 (63)
Critical 3/5/2023 9:11:25 AM Kernel-Power 41 (63)
Critical 2/14/2023 2:16:58 PM Kernel-Power 41 (63)
Critical 2/14/2023 8:02:12 AM Kernel-Power 41 (63)
Critical 2/14/2023 1:43:54 AM Kernel-Power 41 (63)
Critical 2/14/2023 1:07:25 AM Kernel-Power 41 (63)
Critical 2/13/2023 4:09:57 AM Kernel-Power 41 (63)
Critical 2/12/2023 2:55:20 AM Kernel-Power 41 (63)
Critical 2/12/2023 1:43:13 AM Kernel-Power 41 (63)
Critical 2/11/2023 4:09:10 PM Kernel-Power 41 (63)
Critical 2/9/2023 11:34:28 PM Kernel-Power 41 (63)
Critical 2/9/2023 8:38:13 PM Kernel-Power 41 (63)
Critical 2/9/2023 7:51:29 PM Kernel-Power 41 (63)
Critical 2/9/2023 5:14:06 PM Kernel-Power 41 (63)
Critical 2/8/2023 6:16:06 PM Kernel-Power 41 (63)
Critical 2/7/2023 1:23:53 AM Kernel-Power 41 (63)
Critical 2/4/2023 6:24:34 PM Kernel-Power 41 (63)
Critical 2/3/2023 5:24:22 AM Kernel-Power 41 (63)
Critical 2/3/2023 4:04:32 AM Kernel-Power 41 (63)
Critical 2/3/2023 3:16:22 AM Kernel-Power 41 (63)
Critical 2/3/2023 1:19:05 AM Kernel-Power 41 (63)
Critical 2/2/2023 8:57:07 PM Kernel-Power 41 (63)
Critical 2/2/2023 4:48:16 AM Kernel-Power 41 (63)
Critical 1/31/2023 3:44:54 PM Kernel-Power 41 (63)
Critical 1/30/2023 2:21:43 AM Kernel-Power 41 (63)
Critical 1/28/2023 3:34:55 AM Kernel-Power 41 (63)
Critical 1/22/2023 9:27:44 PM Kernel-Power 41 (63)
Critical 1/18/2023 6:46:21 PM Kernel-Power 41 (63)
Critical 1/17/2023 8:18:48 PM Kernel-Power 41 (63)
Critical 1/16/2023 5:19:45 PM Kernel-Power 41 (63)
Critical 1/15/2023 5:30:49 AM Kernel-Power 41 (63)
Critical 1/13/2023 10:41:35 PM Kernel-Power 41 (63)
Critical 1/13/2023 8:14:38 PM Kernel-Power 41 (63)
Critical 1/13/2023 2:23:09 PM Kernel-Power 41 (63)
Critical 1/10/2023 8:11:15 PM Kernel-Power 41 (63)
Critical 1/10/2023 1:28:24 PM Kernel-Power 41 (63)
Critical 1/6/2023 10:20:45 PM Kernel-Power 41 (63)
Critical 1/6/2023 10:11:53 PM Kernel-Power 41 (63)
Critical 1/6/2023 4:49:03 PM Kernel-Power 41 (63)
Critical 1/6/2023 12:19:44 PM Kernel-Power 41 (63)
Critical 1/6/2023 3:34:31 AM Kernel-Power 41 (63)
Critical 1/5/2023 5:41:14 PM Kernel-Power 41 (63)
Critical 1/3/2023 5:07:05 AM Kernel-Power 41 (63)
Critical 1/2/2023 11:55:37 PM Kernel-Power 41 (63)
Critical 1/1/2023 7:25:22 PM Kernel-Power 41 (63)
Critical 1/1/2023 5:57:17 PM Kernel-Power 41 (63)
Critical 12/30/2022 1:28:31 AM Kernel-Power 41 (63)
Critical 12/30/2022 1:13:01 AM Kernel-Power 41 (63)
Critical 12/30/2022 12:43:04 AM Kernel-Power 41 (63)
Critical 12/30/2022 12:19:59 AM Kernel-Power 41 (63)
Critical 12/29/2022 11:42:02 PM Kernel-Power 41 (63)
Critical 12/29/2022 6:33:59 PM Kernel-Power 41 (63)
Critical 12/29/2022 6:26:30 PM Kernel-Power 41 (63)
Critical 12/29/2022 6:03:18 PM Kernel-Power 41 (63)
Critical 12/29/2022 5:31:51 PM Kernel-Power 41 (63)
Critical 12/29/2022 5:05:26 PM Kernel-Power 41 (63)
Critical 12/29/2022 3:34:53 AM Kernel-Power 41 (63)
Critical 12/29/2022 3:28:31 AM Kernel-Power 41 (63)
Critical 12/29/2022 1:25:05 AM Kernel-Power 41 (63)
Critical 12/28/2022 11:42:56 PM Kernel-Power 41 (63)
Critical 12/28/2022 4:49:18 PM Kernel-Power 41 (63)
Critical 12/28/2022 5:05:43 AM Kernel-Power 41 (63)
Critical 12/28/2022 4:57:04 AM Kernel-Power 41 (63)
Critical 12/25/2022 7:13:35 PM Kernel-Power 41 (63)
Critical 12/25/2022 7:01:25 PM Kernel-Power 41 (63)
Jiaszzz_ROG
Customer Service Agent
Hello, OgerGe.
As I replied in another of your comment, please help confirm the following questions:
- Are you unable to start the motherboard after shutdown or sleep?
- What brands and models of PSU you have been cross-teat with an the problem still occurs?
- Please provide the serial number of your motherboard via PM
I will further assist you to confirm, thank you.
Jiaszzz@ROG wrote:
Hello, OgerGe.
Hi. I replied to you via PM.
Yesterday the motherboard turned on normally and today just now it did not want to turn on again making this the 8th time.
Jiaszzz_ROG
Hello, @OgerGe .
We apologize for keeping you waiting due to the new ROG Forum's launch progress.
I have forwarded you case to our relevent team, and will contact you further.
Please feel free to PM me if you continue to experience difficulties or have any other concerns.
