Maximus Hero WIFI XII & Sonic Studio Problem With DCS Simple Radio
scotth
I had this working OK for the most part with the original discs but I was constantly having trouble opening up the Sonic Studio so I downloaded and installed the latest Realtek drivers and software. I really need a graphic EQ that works properly because I have hearing issues and my headphones sound really bad on Discord and DCS Simple Radio without it. The problem I'm running into now is that with the most recent updates to the Realtek drivers and software, DCS SR will not output sound through any of the listed devices. When I run the "Audio Preview" without Sonic Studio installed it works fine and I can get audio through any output device. After I install Sonic Studio the preview stops working and I can't get any sound back from DCS SR or any audio from any other clients. I've tried DTS Sound Unbound and that's even worse. I looked for a rewire or reroute function in Sonic Studio but I'm not seeing any options at all. I have tried installing the previous versions of the Realtek drivers and software but it still won't fix the problem. Is there another EQ option available that will work with Realtek Console or am I stuck with Sonic Studio? Any help on this would be greatly appreciated.
I'm running Windows 10 with all the latest updates.
Senheiser SC 75 USB Headphones
System Specs: Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz 3.79 GHz
32 GB Ram
Windows 10 Pro build 21H2 19044.1645
10 REPLIES 10
scotth
This can be marked as solved or resolved. I got rid of all the Realtek stuff and went back to Creative XFI and removed the audio from the BIOS and everything is working like it should now.
