Hero Xiii disable LED
Psycrow
Level 11
Hi
Is there a way to disable or shut down the start and flex key leds ?
When i power off my pc then all the lights shuts down beside the start and flex key that keeps glowing bright white..it actualy light my whole bed room up :s
So unless i need a black marker or some dark tape..then i would like to know.
STARRAIN_ROG
Customer Service Agent
Hi Psycrow,
Please refer to the following link to try stealth mode in bios.
https://rog.asus.com/support/FAQ/1045607#ggg
Psycrow
Level 11
Yes the system works !! THX ALOT
