G703GX-XB76 PROBLEM: Power via the 2 inputs has become intermittent
g53ok
It is a problem after 5 months of use, it worsens when hot from gaming. A quick reach to push the 90 degree jack back in. This is not about the jack falling out and onto the floor but rather a push in of about 1 mm will fix it, for a second. Also the 2 power bricks are fine, Is there a solution?
Blake1
Hello g53ok,
I'm sorry it's a bit confusing,
do you mean that the power jack is loosen?
or the device is having high temperature and then the power supply is not stable?
g53ok
Well here am i again, now after using it, one of the charge ports has broken.
My new question is locating a pinout for power jack, its the small blue/green wire. What is its purpose?
A schematic is what I need.
