G531GT file copy from phone problem
sackhatri
I am facing a strange problem. When the power supply cable is connected, I am unable to copy medium to large files(say 50MB and above) from my android phone to the laptop through usb cable. Only small files get copied. I get attached error where it gives file copy error due to device disconnected. But when I remove laptop's power cable, the files get copied seamlessly. Why is this happening and how to resolve it?
Falcon2_ROG
Have you changed other cables to test? Does the situation improve if you reboot the laptop?
