09-10-2021 07:50 AM
12-17-2021 05:08 AM
smc007i wrote:
Installing these seems to have worked for me, it's been 2 days now and so far so static outbursts (touch wood) 🙂
12-17-2021 05:18 AM
STARRAIN@ROG wrote:
Hi all,
Please update Realtek USB Audio Driver V6.3.9600.2307 and ALC4080/ALC4082 audio FW update tool released on 2021/12/09.
12-19-2021 08:20 PM
MrAgapiGC wrote:
I open a ticket and sadly and I am sorry, Not all is fix with windows install and rma. sadly i find that my board has no warranty. and i will not apply a rma suggested bu asus support. And also, do not think a recall is needed. the driver manufacture need to step in since is not asus also.
the fw update comes empty. and i am running 6.3.9600.2307 I still have the white noise, now nahimic errors and ui and crash, and the firmware update comes empty And i can not RMA the board. is to expensive to send (as happens with my old monitor) and the local store is ripoff place.
I will start to make a clean install and start from 0 and work with the windows 11 drivers added by itself that as NO issues But i spend 340usd on z590-e in march 2021 and fid out i have no warranty. how long last? less that half a year?
12-17-2021 03:32 PM
STARRAIN@ROG wrote:
Hi all,
12-26-2021 08:27 AM
12-27-2021 07:06 AM
Nathan_Drake wrote:
I have a Z370-E and I was daily driving its S/PDIF port before I switched to the Z690-E. The S/PDIF on the Z370-E didn't have any issue regarding any type of lag. In fact, I used that port to check for lip-syn lag with respect to my HDMI systems. The S/PDIF was rock-solid on my Z370-E. So to say that any type of lag was to be expected only tells me downgrade in newer hardware version is to be expected. Which is, ironically, true in this day and age.
The wakeup lag on my Z690-E is so noticeable that anyone who doesn't notice it should be given an award. It's so easy to reproduce: just go to Windows sound setting, under File Explorer turn on the default sound for Start Navigation. You should hear a "click" sound every time you double click on a folder. Except you won't if you are using the S/PIDF on the Z690-E. The wakeup lag means that you would miss that "click" sound 100% of the time.
Right now I can suggest to my fellow sufferers of this lag problem the following workaround. Download the Spotify app, start the app, play something. You can stop playing as soon as some audio has come out. You can then minimise it or whatever, just don't close the app. As long as the app is opened - you don't even need it to be actively playing something - you shouldn't experience the wakeup lag.
Edit: forgot to mention: I didn't have any joy with the uninstalling Realtek's driver and using the generic driver trick. I seemed to still experience the lag after uninstalling the Realtek driver.
12-27-2021 09:40 AM
Nuckels wrote:
It's not exclusive to S/PIDF either, same occurs on analog.
12-26-2021 01:25 PM
12-29-2021 08:43 AM
Rocket Scientist wrote:
You can use Sound Keeper. It will prevent digital or all outputs (if you wish) from sleep. Just add exe file in autostart folder and launch it.
Add "Digital" in exe file name if you need only prevent SPDIF from going to sleep e.g. DigitalSoundKeeper64.exe
Keep in mind while Sound Keeper process is active it won't allow your PC to go into sleep states as well since it will send 0 or unhearable signal to your speakers (you can change type of signal).
https://veg.by/en/projects/soundkeeper/
P.S. same thing with SPDIF (clicks and beggining of the audio cutouts) also happens with PCIe ASUS sound cards like Xonar AE.
12-29-2021 07:04 PM
Sartigan wrote:
Did this fix your "begining cut off" sound issue? I am using Xonar AE and it still occurs with the program open...
