Coil noise Hero XIII...!
Psycrow
Level 11
I just bought a Hero XIII board with a 11900K cpu amomg other expensive hardware..when i move my mouse pointer around
then i hear coil noise from the cpu area on the motherboard...
I tryed to disable C states and make the same tweaks to bios. but nothing seems to work.
Anyone got a fix ??
Psycrow
Level 11
When i run Prime95 to test the cpu load then the coilwhine is gone !
So it must have something to do with the vcore volt ?!
Any help here ?
How should i tweak the bios ?
Psycrow
Level 11
Bump
Psycrow
Level 11
Baah humbug ! Is this noise on all the Hero boards ?
