Beeps and Q Led issues
Thomas01
I have recently built a new computer and after setting up have had some issues.
First off on start up it will make one long beep followed by three quick beeps and the reset light is flashing at 2 second intervals. The computers fine it starts up and runs with no issues however, the only real concerning bits that some of the ram isn't running at the speed it should.
Here is what it says in the bios-
DIMM_A1 G-Skill 16384MB 2666MHz
DIMM_A2 G-Skill 16384MB 2133MHz
DIMM_A3 G-Skill 16384MB 2666MHz
DIMM_A4 G-Skill 16384MB 2133MHz
As you can see all the ram sticks are the same, but two of them are running slower, we have tried switching the slots, but that tends to cause a ram error and the computer won't start up properly anymore.
Graphics card is a GeForce RTX 4080, CPU is Intel Core i9 13900K and motherboard is PRIME Z790-P WIFI D4.
Any ideas how I can fix this to get the RAM all moving at the same speed and the beeping errors to stop.
6 REPLIES 6
Retired
Not applicable
Mismatched ram... Pull 2 sticks and try... Usually mismatched ram isnt a good practice.
Its not mismatched Rami it is two sets of the exact same ram.
Jiaszzz_ROG
Customer Service Agent
Hello, Thomas01.
When the beeps sound, is there any abnormality at the same time? For instance, can't boot or blue screen?
About beeps, please refer to [Motherboard] How to use buzzer to troubleshoot monitor display issues to confirm the number of beeps and the corresponding issues.
>> https://www.asus.com/support/FAQ/1029959
As your title mentioned about Q-LED, do you have any Q-LED lights up?
Please refer to [Motherboard] ASUS motherboard troubleshooting via Q-LED indicators.
In addition, may I askÂ*what brand and model you use for your memory? Is it on the Prime Z790-P WiFi D4 memory QVL list?
If not, it is recommended that you refer to the purchasing and installation guide and the memory on the memory QVL list to cross-test.
https://www.asus.com/us/motherboards-components/motherboards/prime/prime-z790-p-wifi-d4/helpdesk_qvl...
Jiaszzz@ROG wrote:
Hello, Thomas01.
There are no issues with the computer everything works fine besides the ram not all running at the right speed troubleshooting via Q-LED suggests it may be a graphic card error but nothing really stands out as we have tried resetting it.
RAM is G.SKILL F4-3200C16D-32GTZN and it is on the QVL list though I saw it had some timing settings on the list so will try that.
Update I figure out what was cause the graphics card error it only happens when I turn the computer on before turning my screens on otherwise it is fine and won't beep.
Ramp speed however still won't match.
Jiaszzz_ROG
Hello, Thomas01.
Please refer to page 1 of the user manual for information on the related configuration of PCIe x16 and M.2 slots.
>>https://www.asus.com/us/motherboards-components/motherboards/prime/prime-z790-p-wifi-d4/helpdesk_man...
97615
Meanwhile, it is also recommended that you test with minimal components to isolate the possible cause and cross-test the amount of memory with the slot.
>> https://www.asus.com/support/faq/1042632
