02-12-2021 11:06 AM
06-05-2022 05:46 AM
06-05-2022 06:11 AM
nate152 wrote:
you have to update to the latest version of armoury crate version 5.1.5.0, it's showing the current versions.
Tell me what happens when you click update under check for updates.
06-05-2022 06:32 AM
06-05-2022 12:39 PM
Nate152 wrote:
Thank you,
If Armoury Crate is not updating, use the Armoury Crate uninstall tool from the ASUS Support Center and uninstall Armoury Crate.
Select your operating system then click See all downloads, it's the third download.
https://www.asus.com/us/supportonly/Armoury%20Crate/HelpDesk_Download/
Once uninstalled, install Armoury Crate version 3.1.4.0 and run the updates.
Let me know if this gets Armoury Crate updated to version 5.1.5.0.
04-07-2023 12:49 AM
Hello,
If anyone else runs into this issue, I may have the solution. The headset has a physical mute on it. If you see a red light on the mic the physical mute is on. You need to press the volume control button directly in which will toggle the physical mute.
05-19-2023 04:46 PM
you must be trolling at 1000% lvl
