Hello in a new build i get the d6 error I have tried everything nothing works:( eveything is new exept gpu D6 means No Console Output Devices are found I put the gpu back in the old system and it works perfect exept in the new system it wont work please help
Hi Qwxc12345, Do you mean the pc is booting but no display? Is there any qled on? Which PCIE slot so you install the graphics card in? Please also tried the another PCIEX16 slot and another graphics card. Thank you.
Hi Qwxc12345, Please refer to the following link to check the graphics card and please also try different ports(HDMI/DP) and cables. https://www.asus.com/support/FAQ/1043948/ If you have check all of them and you don't have other graphics card to cross check, please consult the retailer first if you bought it recently. Thank you.
