03-19-2017
07:12 PM
- last edited on
03-05-2024
10:39 PM
by
ROGBot
03-19-2017 07:24 PM
03-20-2017 04:12 AM
Zka17 wrote:
Holy smoke! 4133MHz RAM...
I never had this platform, but from the previous ones I learned that you first OC the RAM (set XMP), then OC the CPU and then combine...
Have you tried the 4133MHz with the CPU on default setting? Do you know that the IMC is able to do it?
03-20-2017 04:29 AM
03-20-2017 12:46 PM
03-23-2017 05:23 AM
Sniper_3001 wrote:
Hmmm. But why can I pass Prime95 and not realbench? I thought prime95 also tests memory stability? Also adjusting vccio will that help out? And how do I figure out by how much? Is there a program to use or just guess?
03-20-2017 12:54 PM
03-20-2017 01:17 PM
03-23-2017 05:00 AM
