XMP BIG Problem
allocen
So my short problem is that due that i enabled the xmp profile for my 4 kits ram, each of 8GB at 2400Mhz, the pc could no longer
start. No signal, not boot splash screen, no nothing.
My specs:
Motherboard: Maximus VII Formula
Processor: Intel i7 4790K at 4Ghz
Ram: 4x HyperX Savage at 2400Mhz each
Cooler: Noctua D14
Video card: MSI R9 280
HDD: 1 TB WD
SSD: Samsung Evo Pro 128gb & Samsung Evo 250gb
Power supply: Seasonic x-1250
So how this started:
So at the recommandation of a friend, he said to me: Why you have bought 32gb ram at 2400mhz with XMP Ready if you
are not using it at its full capacity. (My ram is 4 kits of 8gb each one at 2400mhz, same model HyperX Savage). Without having
the xml profile enabled my ram ran at 1666 Mhz. So i decided to go to the uefi bios and select the xml profile where i saw i had 2 profiles
to choose from, so i selected the first one. All good, till the restart where the pc could not longer send any video signal or the boot
ROG Splash screen. I presed a couple of times on the reset button at the back of my motherboard, clearing CMOS. Finally started but
i was pressing for nothing the DEL button or F2 because it did not want to enter in the BIOS neither way. Tried again and again reset
and reset and nothing, i still got the same result over and over again the code from my motherboard was 55 saying that ram is not
inserted, but what the hell, there is inserted. The funny part is that after each time clearing the CMOS i could enter in Windows but i could
not enter into the BIOS. The weirder part was that even the AI Suite 3 could not start anymore saying something like "failed to call procedure"
or something like that. So this morning i took the ram out from the slots, last 3 ones and i putted them back. At my surprise, i could finally
enter into the BIOS, that code on motherboard this was A2. Before seeing that the xml profile was still enabled even after hundreads
of reset, i pressed already f10 and save, so it was too late... and after the same result i could not longer recieve any signal video
or at least the boot splash screen. So even i press again the reset button i could still not enter into the bios but i can boot into the windows
but after a next reboot i'll have the same behavior as above.
Please anyone, help me, or explain me why is this **** does not work.
I'M DESPERATE
I do not know what to do anymore, i am panicked.
Thank you, Daniel
40 REPLIES 40
allocen
Oke so my friend's cpu is a little older than mine, i have the latest 4 K series generation and he has the 3 series generations. Anyway, what could be? Ya he has 2400 with a single kit, meaning 16 gb ram at 2400mhz. He is using the hyperX Beast series.
