12-04-2015
12:22 PM
- last edited on
03-06-2024
05:39 PM
by
ROGBot
Control Panel > Device Manager > Network Adapters > right click on yours and select the Advanced tab at the top. Locate the "Link Speed & Duplex" selection. Change the option from Auto-negociation (usually standard) to 100 Mbps Full Duplex (Or 1.0 Gbps Full Duplex if you have that option). You may also want to try disabling your wireless adapter while using a wired connection and see if that helps the speed issue.
12-04-2015 01:13 PM
