With closed WC loops such as Corsairs range I don't see why you would want to go air cooling? I would suggest getting a H100 or H100i and you wont need to worry about it, and maybe down the line get some better fans for the Corsair in push/pull.
If you are stuck on air cooling, get the Noctua NH-D14 which is the best of the rest when it comes to after market air cooling
[NEW RIG] Custom Acrylic Loop / i7 8700K @ 5.3GHz 1.34v / Maximus X Formula / G.SKILL Trident Z RGB 32GB 3466Mhz / EVGA 780 Ti Classified's @ 1478mhz SLI / Corsair AX1200i Digital PSU / Samsung 2TB 960 Pro NVME / Corsair 900D / All EKWB
