when idle @ 1600mhz my volttage won't go down...
niwrad33
I think i need to create another thread, can you help please , i just push my system to 4.2 ghz @ 1.162 volts , i just manually change the multiplier and voltage , i run it stable for 2 hours using prime95, but my problem is my voltage wont go down when idle. can you help what i'm goin' to change in the BIOS.
my system:
i7 3770k
M5G
Crucial 4x4gb
Seasonic x-660
Corsair H60
no VC yet
i7 3770k @ 4.0 | Corsair H60 | Maximus V Gene | 4gb x 4 Crucial Ballistix Elite | Asus GTX 660ti TOP | Corsair Force GT 120gb | WD Caviar Black 1TB | Seasonic x-660 | Fractal Design Define Mini |
10 REPLIES 10
niwrad33
1.144v still way up sir , but it is good it comes in lower value but my target is .0888 something like that when idle.
