when idle @ 1600mhz my volttage won't go down...
niwrad33
I think i need to create another thread, can you help please , i just push my system to 4.2 ghz @ 1.162 volts , i just manually change the multiplier and voltage , i run it stable for 2 hours using prime95, but my problem is my voltage wont go down when idle. can you help what i'm goin' to change in the BIOS.
my system:
i7 3770k
M5G
Crucial 4x4gb
Seasonic x-660
Corsair H60
no VC yet
i7 3770k @ 4.0 | Corsair H60 | Maximus V Gene | 4gb x 4 Crucial Ballistix Elite | Asus GTX 660ti TOP | Corsair Force GT 120gb | WD Caviar Black 1TB | Seasonic x-660 | Fractal Design Define Mini |
10 REPLIES 10
stock
Are you in fixed voltage mode or offset?
X-ROG
Level 15
Did you turn of any power savings settings?
niwrad33
Have you seen this Thread OP ??
http://rog.asus.com/forum/showthread...ng-Offset-Mode
i see this thread but it has to be another topic.
all i do is manually change the voltage to 1.16, and manually change the multiplier.
no , i did not do anything in windows a fresh install.
Well it seems like i forgot something to change please advice thanks.
niwrad33
please need advice what should i change in settings it seems my problem is only the idle voltage don't go down.
HotSauceOnPasta
I think MarshallR might have meant power savings settings in BIOS, not Windows.
CRO AIR SLI ROG RIG:
PCMark 7: 6671 3DMark 11: P16718, X6969
MBo: Asus Maximus V Formula CPU: Intel i7-3770k (@4.6GHz)
RAM: Corsair Dominator GT (4x 4GB 2133MHz 9-11-10-27-1T)
GPU: 2x Asus GTX 680 DirectCU II OC in SLI (@1200MHz)
SSD: 2x Corsair Force GT 240 in RAID0
PSU: Corsair AX1200 Cha: Lian Li X500FX
Coo: Prolimatech Armageddon Fan: 5x Prolimatech Vortex Aluminium
Mon: LG IPS235V Cam: Logitech C920 Spk: Logitech Z906
Kbd: SteelSeries 6Gv2 Mou: Cyborg R.A.T. 7 Mat: Razer Sphex
niwrad33
^btw where i can find that seeting in bios?thanks
Krindor
Level 11
Manually setting the voltage will cause it to run at that voltage no matter how fast the CPU runs. To have it change with the CPU using offset will be needed. Follow this guide http://rog.asus.com/forum/showthread.php?2162-Overclocking-Using-Offset-Mode-for-CPU-Core-Voltage&co...
| Chassi: Phantom Fulltower White Edition | Mobo: Maximus V Extreme | CPU: i7 3770k
| Memory: 2x8gb G.Skill Trident X 2400mhz | GPU: PNY Geforce GTX 670 | PSU: NZXT Hale 90 750w
| SSD: Intel 120gb 330 series (OS) | Intel 120gb 330 series (Games n stuff)
| Monitor: LG 29EA93 | Cooling: Custom Loop
HotSauceOnPasta
BIOS power savings settings (I think I haven't missed any):
- Extreme Tweaker: EPU Power Saving Mode
- Extreme Tweaker: EPU Settings
- Extreme Tweaker -> CPU Power Management
- Extreme Tweaker -> DIGI+ Power Control
- Advanced -> CPU Configuration -> CPU Power Management Configuration
- Advanced -> APM: ErP Ready
Check if all (maybe except ErP) are Auto or Enabled.
I changed my multiplier and voltage values to yours (well, my accepted 1.165 instead of 1.162) and, in my case, when CPU idles, voltage does go down, to 1.144.
