04-17-2018 03:33 AM - last edited 3 weeks ago by ROGBot
04-24-2018 05:30 AM
04-24-2018 10:54 AM
Links wrote:
Try increasing "fan ramp up/down" setting in Q-fan control.
This might help against ramping.
For CPU fan I use 30sec, and for the case fan - the biggest value possible, to have the slowest ramping as possible.
Apart from this (my 7700k has heat spikes, as many of them do) I have set the fan graph to star to increase the rpms only from 55c (cpu temp).
04-24-2018 12:19 PM
877cms wrote:
Before thinking of overclocking I would like to know:
What profile should the CPU fans be set to? (3x120mm fans on radiator connected to CPU header).
Best to set this up in bios? At the moment it ramps up and down every few minutes which I find annoying, would prefer more delayed increase.
What are your settings?
Thanks
For info waterloop is as follows:
XSPC 360 radiator > XSPC reservoir > Laing 18W pump > EKWB gpu full cover > vram > EKWB cpu > back to radiator
04-24-2018 09:51 PM
Marko911 wrote:
Bind the pwm curve of radiators fans with loop temperature sensor,so you wont get that awful ramping up and down sound of fans.
04-25-2018 05:29 AM
Links wrote:
Even a better way to deal with the problem.
to 877cms
Plz give a feedback if "fan step up" helps.
