water cooling question?
Fatbeardbag
Alight folk hope yall have had a good day. So I have a question weather a triple 120mm rad will do the job if I'm going to add two gpu's (Asus matrix platinum 7970s) to my loop? Already running a cpu config now so its going to be cpu+gpu setup. I'm not going to be overclocking or anything either just running as packaged.
4 REPLIES 4
Nate152
Hello Fatbeardbag
Adding two gpu's will definitely heat up the liquid but I think you will be ok. A triple 120mm rad should be able to dissipate 600 - 750 watts of heat.
Fatbeardbag
Will do thanks bro.
kkn
Level 14
is it a 40mm or thicker rad?.
Mike482
At the Asset Protection & Elder Law Center, we help our clients protect everyone they love and everything they own. How do we accomplish this admittedly ambitious goal? We begin by asking the right questions and learning about you and your family.
alternative dispute resolution
probate lawyers california
