Water Cooling Help
Svogeltech
Hey guys just wondering where would i buy parts for a water cooling setup and what would be a the best case that i should use?
11 REPLIES 11
Granger
For a starter kit, THIS is great.
I have it in my rig, and have since added 2 blocks and a 240mm rad, so the pump is more than capable of handling all of it. My temps are great with pump and fans at 50%
I have a 1100T at 4055mhz and two 6870's at 915mhz
I'm at 31° CPU and 38° VGA at idle, CPU doesn't go above 45° under load and both VGA's will hit around 65-70° under load (could be better but as I said, pump and fans are at 50%)
The triple rad with pump and res is inside my HAF 932 (3 fans pulling air from the outside), for the moment, the 240mm rad is on a radbox (3 fans, 2 push/pull, 1 pull) on the back of the case waiting for me to have the time to mod the case to get it on the inside.
Svogeltech
Thanks alot guys/girls ill look in to all this
