Volume is too low Asus SupremeFX
Blackwaves
Hi guys , i hope you are going fine , also , i appologize if i posted in the wrong section
Anyway , i own an Asus B85 Pro Gamer , which features Asus SupremeFX . When i installed the given driver with the CD , everything was alright , except that sometimes the volume drops , it's very annoying
I partially solved the problem , what i did is installing the lastest maximus Z97 supremefx driver , the volume doesn't drop anymore , but the maximum volume got veryyyyyy low , on 100% now i have what i had on 30% before
My headphones are the Qpad QH 90 and my OS is Windows 8.1 x64 , do you need guys all the rig ?
I know it's the driver's problem , or maybe an option which i should disable because when i activate the razer surround the volume goes back to it's normal level , but i can't listen to my music in stereo anymore ....
I tried everything ( uninstalling/installing ) , i even installed the realtek official drivers , nothing !
I'm sorry for my bad english and i hope you'll help me
Thanks a lot !
Blackwaves
no answer 😞 ?
