Using ROG Swift as Primary Monitor and PB278Q as secondary?
dedaciai
Hi Everyone,
I am really interested in purchasing the ROG Swift monitor, but I have a few questions about it. My current set up is a PB278Q (awesome WQHD monitor) and I'd like to use it along with the Swift. Basically, I would have the Swift as my primary monitor (using the display port on my GTX 780) and the PB278Q in the DVI port of the same GTX 780. Would having the second monitor mess up G-sync at all (the primary reason I want the Swift)?
The Swift would be for gaming (my primary hobby) and the PB278Q would be for photo/video editing and working in ArcGIS map making.
Thanks in advance!
Dedaciai
Intel Core 3930K at 4.25GHz
Asus Rampage IV Extreme BIOS 1404
Crucial M4 SSD 256GB
EVGA GTX 570 SC 2-Way SLI @ 822/2000/1.038V 24/7 Drivers: WHQL 301.42
2 Caviar Black 1TB HDD
Asus XONAR Phoebus
Corsair H100 (p/p)
Corsair Vengance RAM 16GB @1600MHz
Enermax 1350W PSU
Windows 7 Professional 64-bit
dedaciai
Anybody have an idea? I want to throw money at this thing;), but I want to make sure it'll work as I want it to (stated above). If not, then I'll just throwdown on another PB278Q.
Asus XONAR Phoebus
Corsair H100 (p/p)
Enermax 1350W PSU
kkn
Level 14
its up to you what monitor to use, personaly i have a tv as main and a acer as "slave".
the swift uses a display port ONLY ( non hdmi or dvi from what i know of ).
since the main monitor you game on will be using most of the GPU power ( slave minimum ) for the thing you run on it.
you can deside your self what monitor going to be main and slave.
