UEFI overclock restart problems or not
kaigaming
hello all, i have run into another problem with the maximus formula vi. I finally got my cooler and decided to do some overclocking in the BIOS. However everytime i tweak the multipler or the voltage + save and reset i get some sort of kill power restart. The system turns completely off silenced and then boots back up again. Is this normal?
4 REPLIES 4
HiVizMan
Level 40
Each time you make a change that requires the bios to be retrained you will have that behaviour.
kaigaming
thank you! I got some paper towel shreds under the ROG armor when i was cleaning the thermal paste... Is it okay to just leave it?
HiVizMan
Level 40
Just leave it
