Trouble with fan xpert2, anyone else?
adam2104
Has anyone else tried fan xpert2 to any degree? I'm having two problems with it:
1. If I create custom fan speed curves I can save them with the "Save" button. Then, when I reboot the system, only the chassis fan settings are applied. The CPU fan curve defaults back to something else, its own default I suspect.
2. If I use one of the easy mode profiles, "Standard" for example, no profile gets applied when the system boots up. When I select the "Standard" profile manually the CPU fan dials back and one of the front fans turns off completely. If I reboot the system all the fans come back online at the speed the BIOS controls them at. I have to fire up fan xpert2 and reselect the profile manually to get it doing what it should.
Has anyone else seen this?
15 REPLIES 15
wingcom
For the first part, I am not quite sure...but for the 2nd part, it seems like once you have done the auto tune, the motherboard Super IO chip will take over everything. From my observation, every cool boot will turn on all my fan first and then later dial back to silent mode until the temperature goes up, the fan will then start operating as per the Super IO chip instruction. Not too sure though.
Retired
Not applicable
i am having similar problems. Asus Z77 Deluxe. it seems that fan expert does whatever it wants, regaurdless of what i set. doesn't even need a reboot to start changing settings, just flipping through the fan expert screens and it defaults fans to off, or lower than they were set secodns earlier.
auto is just a bad.
i can't even use speedfan or similar programs, as the fans don't show up.
this program is in my mind a giant POS, when my $17 fan controller does a better job than the super fancy program on my brand new, top of the line board, there is a problem.
I have the same sort of problem with fan xpert 2. I will save a modified profile and fans run nice and silent. Om rebooting the speeds default to some values that are not even the preset ones. Very annoying bug as I though Asus had finally cracked it!
The same problem, P8Z77-V Deluxe, FanXpert2 wont ever apply custom settings after restart. Win7Ultimate 64bit CZ.
I also have the first issue, the software is pretty cool but I have to keep loading the profile every time I reboot.
Retired
Not applicable
I was having the same problem until I disabled the user account control.
I have UAC disabled and it still didn't load the profile for me. Seems like they're going to release an update soon as I found an updated version somewhere else and it does fix the issue.
has this been fixed yet...its driving me mad!!!! :mad:
its bad enough not having proper control over fan speeds and temps in bios, but i cant rely on xpert2 either, if system sleeps or reboots i have to manually go and re select my fan speed profile......
i've tried speedfan 4.46, and finally got it to work, but it only sees 3 fans (out of 5)....
Intel Core i7 -2700K 4600MHz | Maximus V Gene | BIOS 0810 | 16Gb Corsair Vengeance LP @1600Mhz
Gainward GeForce GTX 570 Phantom @Clock 750Mhz Shade 1500Mhz Mem 975Mhz 296.10 drivers
24in ViewSonic VX2453 Series 1080p HD @1920 x 1080 60Hz
2 x 120Gb OCZ-VERTEX3 ATA Device (SATA-III) | 1 x 1TB ST1000DM003 ATA Device (SATA-III) | Corsair 750 AX
Corsair H100 4 x 120mm Noctua NF-F12 PWM (2 Push/2 Pull) | Xigmatek Gigas Black Case
I may have stumbled across a workaround for this while trying to fix this issue for one of my customers. I found just about the same issue you were having.
Our build is using the new P8Z77-V Deluxe board with an Ivy Bridge processor, running Windows 7 64 Bit Home Premium. We experienced the same issue where the computer would start, and immediately revert to the default fan profile (possibly the one stored in BIOS?).
Fan Xpert IS in fact storing your preferences in a startup file, and is loading them when Windows starts according to your last used fan settings. Every time you change an option in the Fan Xpert, it updates the preference file. This preference file is in XML format and for us is stored in C:\Program Files (x86)\ASUS\AsusFanControlService\1.01.02\FanStore.xml
From my testing, it appears that your fan profile loads when Windows starts the AsusFanControlService.exe file. Everything seems to be running fine. Until the USER logs in. If you look in task manager, the service "C:\Program Files (x86)\ASUS\AI Suite II\AsRoutineController.exe -open" runs "On logon of any user", and seems to overwrite user preferences with either a default, or your motherboards settings, causing you to have to "reload" your fan profile.
In my testing, I found that as a workaround, disabling this task in "Task Scheduler" (Windows 7 x64), keeps the last used fan settings active. The only apparent downside so far is that the Asus AI icon does not go into the system tray on startup, however, you can still seemingly launch and use the AI suite from the start menu, and use all of its features as normal without losing your fan settings.
Let me know please if this information was helpful to you!
If anyone else comes across this information, and finds it useful, please feel free to repost it anywhere you wish. It would be nice to have some replies here, so I know that I helped someone out!
