Thanks Chino, unfortunately my H80i was part of the last batch that came with DC fans. They're pretty loud and I'm not sure they're being controlled based on cpu temps. I have mostly plugged it into the CPU_FAN header. I've tried it on the CPU_OPT header once and didn't notice a difference, but I'll try again and see if it provides additional control options. Which header do you recommend for DC fans? For the CPU fans, I'd like them to be controlled by cpu temps.
I believe the H80i is also connected to another PSU cable so I'm pretty sure it's getting all the power it needs for the pump and dual radiator fans. It's a pretty sweet system, I'm just not 100% sure it's working perfectly due to the noise and high core temps (up to 63 C) I'm getting with my 4.5-4.6ghz OC attempts (with a corresponding 76 C cpu temp). So I'm keeping my eye on it, but those temps may be normal for the FX-8150 at those speeds (I'm just not sure). I'm also possibly overvolting my CPU/NB by keeping it on auto as I've been unable to get it stable at these speeds otherwise, and that may be driving up my temps.
