TJ-Max changes from 94 to 103 after OC on 5820k????
yapito
Hello dear folks,
as the titles says would anybody know why this is happening and how can I return tj-max values to default as this is preventing me from correctly seeing my temperature reporting on any various monitoring programs.
The 5820k is riding a x99 deluxe MOBO.
Thanks for all input you kind people 🙂
Chino
Level 15
Hello,
On the Rampage V Extreme, the option you're looking for is called Maximum CPU Core Temperature. It is found in the Advanced tab under CPU Configuration section. I don't own the X99 Deluxe so I'm not sure it that option is available for that motherboard. But at least now you have an idea of what the option is called and where it could be located.
49997
Hi Chino, I know that option, the layout of the Deluxe is just as the one that you have.
The thing is when I manually set that value to 94, as this is the default for 5820k, the bios sets the maximum value to something else, for example 92 or something else but not 94.
The problem for me is that when the bios sets max temp values then I have no idea of the realistic core temps.
