New build as of today...
Asus Crosshair Formula-Z Motherboard
Corsair Dominator Platinum 8x2gb 1600mhz
Samsung 840 Pro 256gb
AMD FX 8-Core CPU 4ghz
XFX R7950 3gb Double Dissipation Video Card
TR2 RX 750W Bronze Power Supply
Thermaltak Overseer RX-I Full Tower
Running with two 20cm fans, one top one front, and 1 12cm fan in the rear.
Motherboard 34C
CPU 40C
Installed GPU-Z and the GPU Temp is currently 61C Fan Speed 33%
CPU is at 45C while running the BluRay movie
Finished up today putting it together, everything seems to be in ordered. Trippled checked it already but the system will shut off and the only way for me to turn it back on is to flip the power switch on the power supply.
Really noticed it when I tried running 3DMark. After the 2nd try, opened the case, touched the board of the video card and it was extremely hot!
Tried Youtube, the temp never changed, I'm playing Indian Jones & The Raiders of the Lost Ark in the background (BluRay quality) and the temp has yet to rise.
I had GPU-Z running and tested it with 3DMark Fire Strike and just before my computer shut down the GPU temp was at 92C
Checked XFX's website to see what they have for info about over heating and this is what was in their FAQ...
"Normal operating temperature should be 30~95 Celsius. Most cards will idle in the 40's or 50's Celsius, and when under a gaming load run in the 70's to 80's . If running an extreme stress test or using the GPU to do OpenCL calculations the card can run into the lower 90's."
So does that mean that its possibly not the video card and I've been focusing on the wrong problem or am I thinking incorrectly that the vid card is over heating when there is a possibility its something with the CPU, or MOBO?
