SupremeFX audio 7.1 does not recognize. asus aid does not update the audio drivers
George348
[Product Information]
Product Type: Motherboard
Product Model: RANGER VII MAXIMUS
Product serial number:
Place of purchase:
Purchase Date: 2015/09/07
[Specifications Motherboard]
Review board basis: no
BIOS revision: the upgrade of the bios 2601-3003
[VGA card Specifications]
VGA Card Manufacturer: gigabyte
VGA card model: HD 7790
Chipset VGA card: Bonaire XT
Driver VGA card: 15.7.1
[Specifications CPU]
CPU Manufacturer: Intel
Type CPU: Celeron G1840
CPU Speed: 2.8
[Specifications Memory]
Memory manufacturer Kingston
Model: DDR3 SDRAM
Memory capacity: 4096 MBytes
[Specifications HDD]
HDD Manufacturer: OCZ
Model HDD: OCZ VERTEX 3
HDD Capacity: 120GB
[Extra card Specifications]
Operating system: Windows 10 64bit
[Description of the problem]
Hello me not working 7.1-5.1-quadraphonic audio only works supremfx virtual 2.1.
Since the purchase does not work use 64-bit Windows 10 and want to continue using it for the direcx12.
My headset worked Zx100 Sony MDR virtual 7.1 sound me with my old motherboard Asus Crosshair V Formula thx but the sound blaster this maximus ranger supremfx not work ..
Connect my headset on the back of the motherboard.
I was recommended to update the bios of 2601-3003 and update the BIOS and use Windows 8.1 and do not want to use the ASUS recommends Windows 10 product.
Still fails downloaded from the official asus site is seen in the photo that 6.0.1.7525 driver. asus months does not update audio drivers .... With whom I complain to continue updating drivers ..
I recommend doing the audio to 7.1 virtual supremfx work?
Please if you have the same motherboard audio and virtual 7.1 surround supremfx works for them.
Answer me using: bios - version windwos - version ROG audio drivers - and in part have the headset plugged in the cabinet or the motherboard that's where I got it plugged. Thank you
0 REPLIES 0
