Strange 3D problem - periodic static only while playing 3D games GTX 670M [pics+vid]
paulinepryz
So guys,
I've been having this issue while playing 3D games, which can only be described as static vertical boxes on the screen that pop up every few seconds. I've highlighted it in the image below.
Before posting I've done my due-diligence by researching, both here, on google and haven't yielded no results. Its really frustrating because I can't play in 3d because it doesn't look normal.
I haven't even been able to find a proper name for what is happening.
Please help!
I've tried the following:
- changing the refresh rate (60,100,110,120) (varies gets worse or better)
- changing the visual theme (gets worse as well)
- changing the resolution (does nothing)
- updating the drivers (currently on 310.70)
- changing brightness levels. (no results)
- fresh install vs. fresh asus recovery disc install
- using a hammer (lol)
Specs:
ASUS 17.3" Laptop - Black (Intel Core i7-3610QM / 1.5TB HDD / 12GB RAM / Windows 7 ULTIMATE)
Model Number: G75VW-QB71-CBIL WebID: 10228336
15129
15126
15127
15128
0 REPLIES 0
