Running 5760x1200 Resolution. Best GPU(s) for that resolution?
_Wyatt_Wallen_
I have teeter-todded between a GTX Titan and GTX 780.
What keeps me considering the GTX Titan is its 6gb vram frame buffer. I feel like that would be an advantageous trait to have down the road say 3-4years from now when I want to run games maxed out at 5760x1200 with consistent 50-60fps.
At the same time though, I have read that 3gb is sufficient for a triple 1200p monitor setup. I find that hard to believe but then again it is heavily weighed on a case-by-case basis. Each game has different requirements and demands.
So, what say of you, people on the forums?
Should I get a single GTX 680 classified, Dual GTX 680s, GTX 780, GTX 780 sli, or a single GTX Titan? (Id prefer not to spend two grand)
What gpu solution would get me the most longevity for my desired resolution and value without spending more than $1400?
All input and advice is welcome.
p.s. A word of note. I am strictly looking at Nvidia solutions for the type of games and work I do. AMD makes wonderful hardware but nothing I can currently take advantage of.
HiVizMan
Level 40
I do not have the screen real-estate to test this. One of the members kkn asked me to try and see if the Titan memory was ever used over 4GB and I could not achieve this.
_Wyatt_Wallen_
Fair enough. I will come to some sort of decision eventually. Thank you for you input.
