06-30-2014 05:31 AM - last edited on 03-05-2024 10:34 PM by ROGBot
ASUS CASEID=RWTM20140627193740516-689 Please click here if you wish to reply this mail!
Dear Customer,
Thank you for contacting Asus Customer Support.
Please be informed that Asus as a manufacturer only offers a warranty service to our customers for faulty units as outlined in the warranty card. Asus do not sell nor provide any parts directly to customers.
In your case you need an extra part to complete your build successfully and I would advise you to go back to the reseller as we can only advise you to buy the required parts via one of the below parts sellers or search online.
http://eshop.asus.com/en-GB/
www.asusparts.eu
www.notebookrepair.co.uk
www.laptop-power.co.uk
www.psaparts.co.uk
www.expansys.com
www.computerbasement.co.uk
Kindly note that the reseller holds the contract of sales with you and might be able to do more for you than Asus.
We are sorry for the inconvenience caused and I do understand this is a very unfortunate situation for you.
Please do not hesitate to contact us again for any further questions.
Kind regards,
Kiona A.
ASUS UK Support team
Hotline: 01442-265548
Email: http://vip.asus.com/eservice/techserv.aspx
Website: www.asus.com
07-03-2014 09:48 AM
07-07-2014 11:09 AM
07-09-2014 05:59 PM
07-10-2014 12:08 AM
DekonX wrote:
Isnt this something that you should look at before you purchase stuff?! I mean obviously you should check the length of the cables and then compare with your case size to see if things will fit/reach. I feel this is more of an issue with the case, unless of course the wires are only like 3inches long. Where as I can see the problem.
Id also like to say that while I do believe that if ASUS is selling this unit. I believe they should have considered WHERE they placed their AAFP connector on the ROG boards since its the furthest possible spot away from the front of the case (well atleast on the crosshair v formula-z board anyways). Id atleast hope they gave you more than ample amounts of cable for a few reasons. Mostly because many cases now are made for wire managment I would hate to have to do a direct run from that thing to my board due to lack of cable.
Anyways a quick search on ebay yielded the expected results for an 11" extension cable that should solve your problem.
http://www.ebay.com/itm/APEVIA-CVTAUDIOE25-11-Audio-Extension-Cable-/191228292615?pt=US_Video_Cables...
Again, I feel that there is probably just a miss communication here for the parts. Im sure that asus probably only intended the front base to be used with certain sized cases as such any that are larger wont necessarily be supported. Many things like this should be explicitly stated so that people know how much cable they will get, while they should also know how much they will need. Its like buying that beasty video card only to find out that your case is too small for it to fit in. I hope that cable I linked will solve your problems though. Im sure you can find one on amazon too. However ebay usually lists all kinds of random chineese things that you only really find if you need it.
07-21-2014 01:04 AM
07-21-2014 09:31 AM
Webalistic wrote:
Such a cable may provide a solution indeed. But the US $58.35 shipping is a bit excessive.
Asus' USA support providing a longer cable tells me they recognised the need for such a thing. However the Asus support in the rest of the world slamming the door in user faces on this thing is annoying to say the least. Just make it available as a part. Resellers have something to sell and make money off. Everybody happy.
07-10-2014 05:58 AM
07-14-2014 12:26 AM
HiVizMan wrote:
I am constantly asking for information re the issues mentioned here. Will post back as soon as I hear anything.
07-14-2014 06:28 AM
07-16-2014 06:09 AM
